Hi everyone, this is a really random question 😂 But can you put the clocks with a rev counter on, into a starlet which doesn't have a rev counter in? Does that make sense? So can you basically swap the clocks over? Thanks.
the toyota paseo dials can be wired in to fit.
i have a set for sale if youre interested? ive got the plugs wired as they should be for it to work so you can either splice it into yours, or change your wires around to match the plugs that i will give you with the clocks
There is another model starlet that basicly plugs straight in with no modifying needed as far as I know, something tells me its the gls model but not 100% sure
Cheers guys, appreciate the help, reason being I've got an SR but it's been shunted up the arse so I plan on breaking it. Buying another and then swapping bits over as need be. Ideally want another SR but if not it'll be a normal starlet. If I end up down stock starlet route I'll give you a shout and have the clocks Ryan :)
I was just abit confused whether the rev counter would work being put in a car which doesn't have one, and is there? I'll have look. Trying to get another SR if I can, but if not it'll be going stock boring starlet route...
