There's no metal fabricators, garages or local welders near you? I'm sure if you gave them a tenner they would weld it for you in there lunch break
U could make up a little bracket that bolts to where the actuator was and the other end hooked over the waste gate arm holding it shut.
I made one of these and then used a threaded bar so you could tighten it shut, did a good job
