Harrychambers21 Posted November 21, 2016 Share Posted November 21, 2016 (edited) Compression results for a forged engine with 1.2 head gasket? Edited November 21, 2016 by Harrychambers21 Quote Link to post Share on other sites
StuDoc 72 Posted November 21, 2016 Share Posted November 21, 2016 You tell us your results and we will tell you if they are ok. We dont know how much has been skimmed off your head regardless of HG thickness. Quote Link to post Share on other sites
Harrychambers21 Posted November 21, 2016 Author Share Posted November 21, 2016 Well it's a new engine and I ran up changed the oil and got from number one on. 126 140 138 140 Quote Link to post Share on other sites
richardc9052 Posted November 21, 2016 Share Posted November 21, 2016 140 is ok for a fresh built low comp engine. But cylinder 1 may be an issue. Why where you doing a compression test? Any reason? If not it may just be that the rings in that cylinder need a little more time and some load. Quote Link to post Share on other sites
Harrychambers21 Posted November 21, 2016 Author Share Posted November 21, 2016 Was just curious really. I no the rings may need a bit of time but the guy said he had an issue with the valve guides so I was wondering maybe that was cylinder one!? Hopefully nothing as it cost a lot! Quote Link to post Share on other sites
fiddlersport Posted November 21, 2016 Share Posted November 21, 2016 Leak down test will be better for diagnosing this issue Quote Link to post Share on other sites
triple j Posted November 21, 2016 Share Posted November 21, 2016 That could very well be valve guides on cylinder 1, have u any smoke when its first started. Quote Link to post Share on other sites
Harrychambers21 Posted November 21, 2016 Author Share Posted November 21, 2016 Did another one tonight just to confirm and with warm engine and throttle open I got 135 150 150 135 so seems to be a bit better. Think once it's all run in should be okay, anyone had dealings with race tech? Quote Link to post Share on other sites
TD04GT Posted November 22, 2016 Share Posted November 22, 2016 Usually a difference of 15psi / 1bar between cylinders indicates a problem in that cylinder, your second test shows that in 1 & 4. Do a leak down test on it and see if it changes the results Quote Link to post Share on other sites
