Hi hope someone can help me.
I know the standard fuel pressure is 2.3bar correct me if im wrong but what does it go upto with the vacuum from the manifold at high revs??
To give you a scope 3.1 should be 1 bar boost. Yes 2.3 bar is correct. There is no need to mess around with the fuel pressure regulator. Mapping is the key.
Just looking for info really not going to be messing with the pressure yet, just noticed the injectors respond well to pressure increases that all and didnt know what pressure the reg increased to with vacuum
now now now thats a really hard `1 to tell as when flat out under load most guys and girls will be behind the wqheel
why are you asking this whats your problem kid ???
