... I took of my rear door pannels on my ep82 and realise it's rusty on the floor from the wheel arch all the way down im guessing to the end where the front door is. As I can not see even if I take the plastic trim off if that makes sense. Is there anyway of actually removing some part so I can get in there and sand it all down and spray it etc. Any help would be great. Thanks Aaron
Common area I've discovered myself for ep82 to start rotting. But nobody notices it unless it's stripped. As above replacing sills if it's bad is your only option
