Got an ep80 rack here. You will need the steering column too as they are longer. You can remove your original steering column and change the steering shaft that runs up the middle of the column to keep your adjustable steering wheel height.
Got a stock gt rack up in the Rhondda if you have no luck mate.
Cheers mate will give you a shout if I can't get hold of one would prefer to go non power steering though if I can!
