MR-2 Posted December 23, 2016 Posted December 23, 2016 (edited) I bought EP91 anti lift kit to my EP70.I have new EP70 arms, but not using these, saving these for future spare part purpose. Taking my old arms from car and those should be same. Was wondering is EP91 arm rear rod same about 16mm thikness as E70?Question ends should that old sleeve needed or does this bushing just go without sleeve, something won't match this thing? How these are installed to EP91 arms, just pushed to rods? Edited December 23, 2016 by MR-2 Quote
morgey Posted December 23, 2016 Posted December 23, 2016 Cut that sleeve off carefully and it pops right on Quote
MR-2 Posted December 23, 2016 Author Posted December 23, 2016 Cut that sleeve off carefully and it pops right onEasily can destroy bush and sleeve, but do I need old sleeve for new bush? Quote
morgey Posted December 23, 2016 Posted December 23, 2016 Cut the bush and sleeve off, The ALK sits on the pin that remains. Quote
MR-2 Posted December 23, 2016 Author Posted December 23, 2016 Cut the bush and sleeve off, The ALK sits on the pin that remains.Okay, thanks, better be sure Quote
morgey Posted December 24, 2016 Posted December 24, 2016 If youre still a bit unsure remove the bush and try the Alk on over the sleeve. You'll soon be able to tell if it needs removing Quote
5e colin Posted December 24, 2016 Posted December 24, 2016 bush wont slot over sleeve unless forced sleeve comes of on both powerflex and jezzas kits Quote
