gorganl2000 Posted January 24, 2017 Posted January 24, 2017 i know forged pistons for our engines are advertised in 74.0mm/74.5mm/75.0mm sizes my question - is the advertised size the actual size of the pistons? or is it actually a little smaller and more like the stock size 73.90mm - 73.93mm? Quote
epcashin Posted January 24, 2017 Posted January 24, 2017 yes its the actual size bit silly If it wasnt Quote
gorganl2000 Posted January 24, 2017 Author Posted January 24, 2017 yes its the actual size bit silly If it wasnt thanks just always good to make sure...though i know each block must be machined to suit Quote
5e colin Posted January 24, 2017 Posted January 24, 2017 you get a spec sheet with actual size to bore to for a given set of pistons diferent brands have diferent sizes Quote
Ollieh17 Posted January 24, 2017 Posted January 24, 2017 thanks just always good to make sure...though i know each block must be machined to suitit's not the actual size Quote
gorganl2000 Posted January 24, 2017 Author Posted January 24, 2017 (edited) you get a spec sheet with actual size to bore to for a given set of pistons diferent brands have diferent sizes cool colin it's not the actual size ok, let's say a popular brand like wossner, what is the actual size of a 74mm or 74.5mm wossner piston? seems a lot of members use this piston in their builds and what kind of bore clearance is recommended on the spec sheet that colin mentioned? Edited January 24, 2017 by gorganl2000 Quote
gorganl2000 Posted January 25, 2017 Author Posted January 25, 2017 i was doing some research and its just seemed a bit weird that in some older posts that some just appeared to hone the block and insert the forged pistons---well for standard size 74mm....as opposed to going the machine shop route and getting a proper rebore to specs Quote
epcashin Posted January 25, 2017 Posted January 25, 2017 74mm waste of time be too much piston slap74.5 and bore the block .5 much better Quote
