marki7 Posted January 27, 2017 Posted January 27, 2017 Hey all..few symptoms with my v at the minute.Rough idle,try to rev it and it splutters,strong smell of fuel round inlet manifold/fuel rail only when u rev it,engine light is on,also all three boost lights are on.Checked for leaks in the whole bay air,fuel and water. Tried resetting the ecu still the same.checked plugs and leads. Thanks for any help guys and gals. Quote
akyakapotter Posted January 27, 2017 Posted January 27, 2017 First port of call is a self diagnostics test find out what flash codes are stored then go from there.http://www.toyotagtturbo.com/forums/showwiki.php?title=EFI+self-diagnosis+systemCheers nick. Quote
marki7 Posted January 27, 2017 Author Posted January 27, 2017 Cheers for that link nick will give it a look tomorrow Quote
marki7 Posted January 28, 2017 Author Posted January 28, 2017 Ok getting 31 and 34. Read 31 is map sensor.And 34 turbo pressure. Are these right Quote
Starlet__SR Posted January 29, 2017 Posted January 29, 2017 If the map sensor is misreading it'll give these codes. Quote
maddox710 Posted January 29, 2017 Posted January 29, 2017 If you have a hks fcd or similar device, check wiring on that as that intercepts maps sensors voltage Quote
marki7 Posted January 29, 2017 Author Posted January 29, 2017 No fcd. Do I need to swap out the map sensor or look at other things first. Cheers for the help lads Quote
