Sparkythestarlet Posted February 7, 2017 Posted February 7, 2017 hi guys where do people normally fix there 4 point harness to on there starlet? Quote
akyakapotter Posted February 8, 2017 Posted February 8, 2017 there you go bud. my harness are fitted in the rear oem belt points front is in the oem points and to my seat its self need to change that at some point. http://www.securon.co.uk/fitting/extras/fiaharnessfitting.htm Quote
Nanglebadger Posted February 8, 2017 Posted February 8, 2017 the rear straps in mine are as above, the fronts are eye bolts, one into the sill where the OEM lower seat belt bolt goes (should screw straight in depanding on thread size of eye bolt), and the other into the transmission tunnel where we widened the original seat rear mount hole to fit washer and nut via the transmission tunnel (i.e. underneath the car, up above the exhaust). Phil. Quote
Sparkythestarlet Posted February 13, 2017 Author Posted February 13, 2017 what size are the eye bolts that go into the transmission tunnel? Quote
