gorganl2000 Posted February 16, 2017 Posted February 16, 2017 (edited) i've tried a search, but didn't find much. anyways, does using the thinner 0.5mm 5efe or 0.6mm trd headgaskets with forged wossner pistons allow for adequate pistons/valve clearance? and will this make the engine an inference engine or does it still remain a non-inference engine in case the timing belt snaps? and how about if stock 4efte pistons are used in the same scenario? Edited February 17, 2017 by gorganl2000 Quote
goldenvtr Posted February 16, 2017 Posted February 16, 2017 i've tried a search, but didn't find much. anyways, does using the thinner 0.5mm 5efe or 0.6mmtrd headgaskets with forged wossner pistons allow for adequate pistons/valve clearance? and will this make the engine an inference engine or does it still remain a non-inference engine in case the timing belt snaps? and how about if stock 4efte pistons are used in the same scenario? ive just built a new 5e with -10cc pistons 0.5mm gasket and both head and block have been skimed good news its higher compression ratio without loosing squish. bad news is its now an interference engine should the belt ever snap Quote
karl. Posted February 16, 2017 Posted February 16, 2017 ive just built a new 5e with -10cc pistons 0.5mm gasket and both head and block have been skimed good news its higher compression ratio without loosing squish. bad news is its now an interference engine should the belt ever snapWhat turbo will you be running? I have built a the same 5e only with some speedvison cams. Quote
gorganl2000 Posted February 17, 2017 Author Posted February 17, 2017 (edited) ive just built a new 5e with -10cc pistons 0.5mm gasket and both head and block have been skimed good news its higher compression ratio without loosing squish. bad news is its now an interference engine should the belt ever snap hey goldenvtr, how goes it boss so it turns without any piston/valve contact then? i think wossner are 6cc dish i wonder if using the stock 1.2mm headgasket will allow it to remain non-inference?---it should in theory?! Edited February 17, 2017 by gorganl2000 Quote
goldenvtr Posted February 17, 2017 Posted February 17, 2017 hey goldenvtr, how goes it boss so it turns without any piston/valve contact then? i think wossner are 6cc dish i wonder if using the stock 1.2mm headgasket will allow it to remain non-inference?---it should in theory?! im good dude,yourself? unfortunately i can answer that, it would have to be trial and error i suppose...im presuming i don't make valve to piston contact as it runs ok, but i do have a tapping noise issue at the moment, so im going to borrow a boroscope to make sure. dont want to clog this thread so see my other one i made for info... theoretically i should have a 9.1ish CR with: 74.5mm bore 75mm headgasket 39cc original combustion chamber (but head 1.77mm skim) 87mm rod stroke 5e block decked by 2mm pistons deck clearance is 0 -10cc pistons 0.5mm head gasket (metal no additional squash) Quote
gorganl2000 Posted February 17, 2017 Author Posted February 17, 2017 (edited) im good dude,yourself? unfortunately i can answer that, it would have to be trial and error i suppose...im presuming i don't make valve to piston contact as it runs ok, but i do have a tapping noise issue at the moment, so im going to borrow a boroscope to make sure. dont want to clog this thread so see my other one i made for info... theoretically i should have a 9.1ish CR with: 74.5mm bore 75mm headgasket 39cc original combustion chamber (but head 1.77mm skim) 87mm rod stroke 5e block decked by 2mm pistons deck clearance is 0 -10cc pistons 0.5mm head gasket (metal no additional squash) i'm cool sir i just found the tread you are referring to ...thanks Edited February 17, 2017 by gorganl2000 Quote
goldenvtr Posted February 17, 2017 Posted February 17, 2017 What turbo will you be running? I have built a the same 5e only with some speedvison cams. havnt decidedyet, ive put a td04 on to run it in lol its a tos up, retry my td0520, it was too laggy on the old engine but with this CR should be more drivable. or vf34/vf22 for less power but wider powerband... really dont know haha Quote
gorganl2000 Posted February 18, 2017 Author Posted February 18, 2017 if you do change from the td04 after run in, ,,of the 3 last turbos you mentioned, i'd go for vf34 Quote
