Georgehburroww Posted March 7, 2017 Posted March 7, 2017 So I've got a UK spec non turbo ep91 and am doing a restoration and turbo conversion, I'm aiming to run a td04 and be pushing out around the 200hp, I want to hear from you lot about what sort of brake setups you would recommend? I have also have some glanza brake calipers and the turbo and non turbo calipers seem to be identical??? What would you lot do in terms of brakes if pushing out 200hp?? Quote
BMX-RIG Posted March 7, 2017 Posted March 7, 2017 Calipers are the same. glanza carriers are bigger to allow a larger disc Quote
