sosolid Posted March 26, 2017 Posted March 26, 2017 Mines a 96 Glanza V so what type of oil pump do i need? There two types seal on block 15100-11071 and 15100-11070 seal on pump. Which one is mine? Quote
akyakapotter Posted March 26, 2017 Posted March 26, 2017 Imo id whip yours off and check that way then you no 100% which one you need. Cheers nick. Quote
patman Posted March 26, 2017 Posted March 26, 2017 Yep thinking the same thing in theory having a glanza you should have seal on block but as nick above said you never know and you might just have a GT block in it Quote
sosolid Posted March 27, 2017 Author Posted March 27, 2017 hmmm engines not been swapped. its the original. having read somewhere the early model gts had seal on pump. later model grs and glanzas are seal on block Quote
