gorganl2000 Posted April 4, 2017 Posted April 4, 2017 hail, can anyone post on here or provide me with a complete copy/scan of the specifications sheet for wossner forged pistons? it would be very much appreciated. thanks Quote
gorganl2000 Posted April 5, 2017 Author Posted April 5, 2017 (edited) anyone? ..i'm referring to the installation informaiton---like ring gapping, etc http://www.ukstarletowners.com/topic/52242-how-to-build-a-5e-fte-engine-5e-conversion/?hl=%2Bwossner+%2Bpiston+%2Bspecs i found a little on this tread, but not all Edited April 5, 2017 by gorganl2000 Quote
5e colin Posted April 5, 2017 Posted April 5, 2017 there not al going to be same each sheet if specked to a set of pistons get your machinist to measure them before he bores block he will bore each 1 then to the piston spec and mark the pistons Quote
gorganl2000 Posted April 5, 2017 Author Posted April 5, 2017 (edited) there not al going to be same each sheet if specked to a set of pistons get your machinist to measure them before he bores block he will bore each 1 then to the piston spec and mark the pistons yeah i know that the bore is supposed to be the specified piston size ---which included a 0.07mm or 0.0027" clearance. i'm talking about the ring gapping, ring alignment, etc specs http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf like how we have that for wiseco Edited April 5, 2017 by gorganl2000 Quote
ramses Posted April 11, 2017 Posted April 11, 2017 anyone? ..i'm referring to the installation informaiton---like ring gapping, etc http://www.ukstarletowners.com/topic/52242-how-to-build-a-5e-fte-engine-5e-conversion/?hl=%2Bwossner+%2Bpiston+%2Bspecs i found a little on this tread, but not all All i can tell you that there are 2 set one if the old and provide you §BAD SERVICE from WOSNER and the other is the more known .... 3 set of WOsner pistons and still get the oil problem ...;my other car is a mazda and i swap to JE PISTON and they are better ... Quote
gorganl2000 Posted April 12, 2017 Author Posted April 12, 2017 All i can tell you that there are 2 set one if the old and provide you §BAD SERVICE from WOSNER and the other is the more known .... 3 set of WOsner pistons and still get the oil problem ...;my other car is a mazda and i swap to JE PISTON and they are better ... http://www.wossnerpistons.com/tech/piston-installation i found this, but i find it strange that both the top and 2nd ring gaps are the same 0.006" x bore isn't the top ring gap usually a little tighter tolerance wise then the 2nd ring gap----maybe like 0.0055" x bore OR 0.005" x bore ??? anyone with this kind of experience/knowledge? Quote
AdamB Posted April 12, 2017 Posted April 12, 2017 I would expect a larger clearance on the first ring because it's closer to the piston crown, ie maximum heat and therefore would close up more under higher pressure and temperature.No harm in running the same clearance on both rings. Quote
AdamB Posted April 13, 2017 Posted April 13, 2017 In here matehttp://www.ukstarletowners.com/topic/58187-how-to-build-a-forged-5efte-engine-step-by-step-guide/ Knew I had seen the specs somewhere Quote
gorganl2000 Posted April 13, 2017 Author Posted April 13, 2017 In here mate http://www.ukstarletowners.com/topic/58187-how-to-build-a-forged-5efte-engine-step-by-step-guide/ Knew I had seen the specs somewhere yeah...i had seen that one and linked above...was just hoping to get the entire document if possible Quote
AdamB Posted April 14, 2017 Posted April 14, 2017 Clock the ring gaps 90 degrees apart.Follow that spec for ring gapUnsure on piston-cylinder clearance, this depends on what it's going to be used for, can run tighter if it's just a street motor, but something that's constantly at high rpm will require larger. Quote
gorganl2000 Posted April 15, 2017 Author Posted April 15, 2017 seen specs online say 0.07mm which is about 0.0028" bore clearance Quote
