StanMan Posted April 26, 2017 Share Posted April 26, 2017 (edited) Hi guys. Does anyone know the torque for the Whiteline Anti-lift kit (the 4 M12 cap heads)? It says to torque to standard spec which I think is 155nm as standard bolt is marked as '10' on the head. I don't want to break the captive nut on the inside of the chassis and cause an absolute nightmare. Thanks. Edited April 26, 2017 by StanMan Quote Link to post Share on other sites
MR-2 Posted April 27, 2017 Share Posted April 27, 2017 Try 155Nm and it will snap for sure, more like 50Nm... Quote Link to post Share on other sites
StanMan Posted April 27, 2017 Author Share Posted April 27, 2017 (edited) According to this it's 155nm? They are 12.9 cap heads. But originally M12 Toyota flanged bolt marked with a 10 on the head. Edited April 27, 2017 by StanMan Quote Link to post Share on other sites
MR-2 Posted April 27, 2017 Share Posted April 27, 2017 I found my EP70 chassis manual 87Nm value for that bolt, should be almost same as newer model. Quote Link to post Share on other sites
StanMan Posted April 27, 2017 Author Share Posted April 27, 2017 I found my EP70 chassis manual 87Nm value for that bolt, should be almost same as newer model. Great, thanks for that. I did it to 80Nm in the end, so not far off. Quote Link to post Share on other sites
MR-2 Posted April 27, 2017 Share Posted April 27, 2017 Your welcome I mostly trust my own hands and feeling only. Using torque tools only in some important engine bolts and nuts. Trust Yourself Quote Link to post Share on other sites
