The headlight loom is part of the fusebox, and that plugs into the dash loom, on the NS. The connectors are slightly different between MK2 and MK3.
Thats not the way people do it.
You can splice the wires into the existing loom, but the operation is not exactly the same as an actual quadlight.
You have to get the correct brackets too or make your own.
Also the rear of the quadlights are bigger, so youve got to make them fit in a space theyre not ment to.
