Hi people. Just coming round to putting the head back on the car now. Just wondered what lube i should use on the threads and under the heads of the arp bolts? Also what are the correct torque settings?
Thanks
I'd just order a sachet of eBay, but make sure they are clean again before putting back in. I've heard of people using engine oil but I would only advise what arp recommend I with their bolt and assembly process
Make sure the threads on the block are clean and free of dirt. I used break cleaner and a tiny wire brush.
The bolts need to be torqed to 60nm using arp grease
