I am looking to uprate my map sensor I am pretty sure I can use a orange map sensor off a Toyota mr2 just wanted to make sure this is correct and to what bar these can be used at also is it a map sensor from any turbo mr2 aslong as it's orange or does it have to be a specific generation
Wrong mate... you need the celica gt4 map sensor that will need scaling by the mapper if your running an apexi power fc the map sensor has a purple sticker. Good for 1.8bar max
Edited by H_D
