HarrisonS Posted June 5, 2017 Posted June 5, 2017 As we all know the speakers that come with the car are terrible and it's difficult to get any bass from replacing the stock 4" speakers. I have read that there is wires in the back of the car for optional rear speakers and I've had a look and I think I've found them I just want to make sure. The wires I have found are all grounded but one is brown (ground) and then there is a yellow and brown one (hoping to be speaker) and then a plain yellow one (hoping to be positive). There is a picture below. I would just like to know what the wires are and if they are speaker wires if there's a another on the other side of the car for the left speaker or if it all goes through those wires.Any help massively appreciated Quote
TRD-1 Posted June 8, 2017 Posted June 8, 2017 These don't look like speaker wires, its a earthing point for something, removing it will make something not have a ground connection i.e not work. Im guessing speaker wires will be either in a connector that isn't connected to anything, or taped down somewhere along the loom. Quote
Pete_A Posted June 8, 2017 Posted June 8, 2017 I just ran some wires straight from the stereo under the centre console/seats that just popped out in the centre of the boot took 20mins Quote
HarrisonS Posted June 8, 2017 Author Posted June 8, 2017 (edited) I just ran some wires straight from the stereo under the centre console/seats that just popped out in the centre of the boot took 20mins Okay cheers I'll just do that then. For the wires you ran which wires behind the stereo did you take the signals from? Edited June 8, 2017 by HarrisonS Quote
HarrisonS Posted June 8, 2017 Author Posted June 8, 2017 The rear outputs?!Any idea on colours etc I assumed the rear outputs Quote
Pete_A Posted June 9, 2017 Posted June 9, 2017 Put the fader to the rear nd touch wires on til you get noise. Quote
HarrisonS Posted June 9, 2017 Author Posted June 9, 2017 Put the fader to the rear nd touch wires on til you get noise.Okay cheers Quote
ryan lang Posted June 9, 2017 Posted June 9, 2017 if you have a recent head unit. they should be labelled as rear speakers on the wires. running them under the centre console and under the carpet and seats takes 2 minutes Quote
HarrisonS Posted June 9, 2017 Author Posted June 9, 2017 if you have a recent head unit. they should be labelled as rear speakers on the wires. running them under the centre console and under the carpet and seats takes 2 minutesAlright brill thanks Quote
westie Posted June 12, 2017 Posted June 12, 2017 There should be an unused plug taped into the loom under the drivers side plastic in the boot. This plugs straight into a plug on the parcel shelf from a CD spec UK car which had rear speakers as standard. Quote
morgey Posted June 12, 2017 Posted June 12, 2017 As westie said. Should be a plug, Cd's and sr's came with them stock Quote
HarrisonS Posted June 12, 2017 Author Posted June 12, 2017 There should be an unused plug taped into the loom under the drivers side plastic in the boot. This plugs straight into a plug on the parcel shelf from a CD spec UK car which had rear speakers as standard.I've had a look and couldn't find anything but I just probably didn't look hard enough. I'll have a better look at some point. Cheers Quote
