Hello guys,
Quick one there's two types of ct9 turbos i have seen, one with Toyota written on the top and one with Toyota ct9 written on top is there any difference between the two?
Regards Tez
Looking at images from google it seems the compressor housing is in a different rotation, the actuator sits in a different spot and the exhaust manifold seems to have a different bolt pattern. However some parts can be used:
http://www.toyotagtturbo.com/forums/showthread.php?104393-Rotating-CT9-housing
@Starlet__SR theres difference in the bearing cartridges aswell, as I could not fit a B compressor wheel housing on an A cartridge and vice versa
Edited by maerijn
