Hey all, ive been looking into making a hybrid 6 speed using a c64 i have and a c52. That fell flat on its face a bit when i found they have the same top gear lol but i did stumble across this:
http://www.hangar111.com/shop/lotus-2-eleven-gearbox-a-clutch/445-toyota-elise-exige-2-eleven-jubu-racing-gearset-2zz-c64-gearbox.html
Would they fit in a c52? I know theyre straight cut but everyone blows up 3rd making big power and that looks like a possibility to me
Edited by Chops
I was hoping to make a hybrid of the two, dunno if i might just look at fitting these two aftermarket gears in a c52 now tbh
It should work, the extra gear on the 60 series is outside the main cluster.
Worst case just use the whole c60/c63/c64 box
Use a gt shafts and diff with the final drive from the 60 series box
Phil
Use the outer cvs of the gt and the whole c60/63/64 set up and make a bracket for the intermediate bearing carrier would be the job.
After market lsd and equal length shafts
There is cheaper straight cut gears than hanger111 also. And proven to 500hp
Phil
Edited by Phil
