Zak.p Posted July 14, 2017 Posted July 14, 2017 Looking for a silicone elbow to fit on the air intake of td04 to fit my air filter what size diameter hose would I need to fit the intake properly have seen a few different answers, cheers Quote
TimD Posted July 14, 2017 Posted July 14, 2017 This might sound crazy.. but have you thought about measuring it yourself? You aren't measuring bearing clearances, just use a ruler, or tape measure to give you an idea and order something as close as you can find. Quote
Whitenoize Posted July 14, 2017 Posted July 14, 2017 57mm I used a bike carb filter if your short of space Quote
Zak.p Posted July 14, 2017 Author Posted July 14, 2017 Yea Tim I was going to measure myself but not with the turbo for a few days and wanted to get the hoses ordered & nice one cheers noize will get looking for one now Quote
Zak.p Posted July 16, 2017 Author Posted July 16, 2017 Can only find a 57mm unfortunately hoping that should be ok with real tight clamps etc, what you reckon? Going 57mm-76mm silicone 90 from turbo then 76mm alloy 90 to a small 76-83mm hose joiner to filter only way can do it with this apexi filter really Quote
5T4R7ET N/A Posted July 17, 2017 Posted July 17, 2017 Can you get 54? Sent from my iPhone using Tapatalk Quote
Whitenoize Posted July 17, 2017 Posted July 17, 2017 Can you get 54? Sent from my iPhone using Tapatalk 57mm would be fine for 54mm it would tighten 3mm easily Quote
