ashbuxton Posted July 31, 2017 Share Posted July 31, 2017 Contemplating buying some second hand WMS brakes from a guy who is breaking a glanza. My question is will they fit my 95 GT? Or will any modification be needed or will they be completely wrong? Never really messed with brakes before on a starket so don't know? Thanks 👍 Quote Link to post Share on other sites
morgey Posted July 31, 2017 Share Posted July 31, 2017 All turbo brakes from 92-on are the same mate, they'll be fine. Only thing you may want to check is wheel clearance but there is a PDF file of each kit in the WMS section, you can print out and try inside your wheel. All you need to know is what size kit he has. Quote Link to post Share on other sites
ashbuxton Posted July 31, 2017 Author Share Posted July 31, 2017 Thanks morgey. I'm having his wheels aswell I think so should be fine 😂 Nice one for clearing that up for me much appreciated! Sure there will be something else I need advice on when fitting them so keep your eye out for a post from me 👍 Quote Link to post Share on other sites
morgey Posted July 31, 2017 Share Posted July 31, 2017 As long as you get the brake lines too you should be fine mate. Quote Link to post Share on other sites
ashbuxton Posted July 31, 2017 Author Share Posted July 31, 2017 Yes comes with all lines and everything mate it's the full kit Quote Link to post Share on other sites
StanMan Posted August 1, 2017 Share Posted August 1, 2017 (edited) Only different thing is the Hubs as they are 54mm on GT turbo instead of 55mm on the Glanza, there are also 3 types of mounting bracket dependant on disk size I think. You will need to measure the disks when buying new ones as there are 3 different sizes of disk 275 x 22 / 277 x 25 and a massive 295x26. http://www.ukstarletowners.com/topic/28282-wms-brakes-for-54mm-hub-starlets-92-ep82/ That explains it all Edited August 1, 2017 by StanMan Quote Link to post Share on other sites
morgey Posted August 1, 2017 Share Posted August 1, 2017 Only different thing is the Hubs as they are 54mm on GT turbo instead of 55mm on the Glanza, there are also 3 types of mounting bracket dependant on disk size I think. You will need to measure the disks when buying new ones as there are 3 different sizes of disk 275 x 22 / 277 x 25 and a massive 295x26. http://www.ukstarletowners.com/topic/28282-wms-brakes-for-54mm-hub-starlets-92-ep82/ That explains it all This is only on the pre 92 Gt's all later ones had the same 55mm as all the rest Quote Link to post Share on other sites
StanMan Posted August 2, 2017 Share Posted August 2, 2017 This is only on the pre 92 Gt's all later ones had the same 55mm as all the rest Quote Link to post Share on other sites
DRiiFTiE Posted August 2, 2017 Share Posted August 2, 2017 That will be me.. ;) Quote Link to post Share on other sites
ashbuxton Posted August 2, 2017 Author Share Posted August 2, 2017 That will be me.. ;)Ahhh right assumed you'd be on here but obviously the name doesn't give it away. Good job wasn't slagging you off haha Quote Link to post Share on other sites
DRiiFTiE Posted August 2, 2017 Share Posted August 2, 2017 Ahhh right assumed you'd be on here but obviously the name doesn't give it away. Good job wasn't slagging you off haha I thought the same haha. Quote Link to post Share on other sites
ashbuxton Posted August 2, 2017 Author Share Posted August 2, 2017 Look forward to hearing from you when the bits are off anyway mate. Like I said no rush or pressure for you to get them off this end really just let me know when you ready for me to collect. Quote Link to post Share on other sites
