gorganl2000 Posted August 2, 2017 Posted August 2, 2017 (edited) hail all, how accurate is the stock rev counter?the stock rev limit is supposed to be 7200rpm so in theory the stock ecu enforces the rev limiter (fuel cut) at this point and the stock rev counter should reads the same 7200rpm are persons with stock set up noticing any difference on their oem rev counters? i know some of you have standalones/piggyback installed, so i'm wondering if your stock/oem rev counters and management logs read the exact same rpms as well? if there is a rpm difference, how much is the rpm difference? does this difference worsen as the rpms get higher or remain the same throughout the rev range? Edited August 2, 2017 by gorganl2000 Quote
morgey Posted August 2, 2017 Posted August 2, 2017 Mines not stock but its an OEM toyota setup just a different engine, when i stuck it on the dyno they told me it was about 200rpm out, think it was over reading but im not 100% on that Quote
Stu Posted August 3, 2017 Posted August 3, 2017 Ive replied to your PM but yes they do read a bit out. Just rev till bust Quote
gorganl2000 Posted August 4, 2017 Author Posted August 4, 2017 thanks morgey and stu.PS ---there will be no revving till bust lolol Quote
