glanza ep91 23 Posted August 18, 2017 Posted August 18, 2017 (edited) Hi i broke the 10mil bolt that hold on the dust plate and now im wondering can u run a manual without one thanks Edited August 18, 2017 by glanza ep91 23 Quote
glanza ep91 23 Posted August 18, 2017 Author Posted August 18, 2017 Basicaly i cant get the bolt out its spinning. So will i cut the dust plate along the lines or will i just run without it Quote
AdamB Posted August 18, 2017 Posted August 18, 2017 Try and get a very thin flatblade screwdriver under the head of the bolt, and lever it as you undo it with a ratchet. Quote
glanza ep91 23 Posted August 18, 2017 Author Posted August 18, 2017 Ya tried that ended up taking the head of the bolt off now im wondering will i cut the dust plate at the lines drawn or leave it off Quote
daniel_g Posted August 19, 2017 Posted August 19, 2017 Better off leaving the plate on. The bellhousing bolts hold it in well enough. Quote
