glanza ep91 23 Posted September 3, 2017 Posted September 3, 2017 (edited) hi i install a wheel bearing and the bearing split a few times is that normal? And ive installed the hub plate and there a small wobble is that ok? Edited September 3, 2017 by glanza ep91 23 Quote
Ep82gi Posted September 3, 2017 Posted September 3, 2017 What do you mean it's split a few times it looks fine in the picture. And as for the wobble did you make sure they where seated all the way to the bottom all the way round. And tightnen the hub nut correctly and check again once you have done a few miles Sent from my iPhone using Tapatalk Quote
glanza ep91 23 Posted September 3, 2017 Author Posted September 3, 2017 Ya there just a small bit of play in it when i fit the driveshaft and tighten the nut ill see thanks Quote
HarrisonS Posted September 7, 2017 Posted September 7, 2017 Just wondering how difficult is it to change the wheel bearing? I'm assuming this is the front Sent from my iPhone using Tapatalk Quote
