Mxdsnny Posted November 26, 2017 Posted November 26, 2017 6 speed gear from a rolla g6. Will it fit a 4efe. Do you need a different clutch? Do they have better ratio? Quote
5e colin Posted November 26, 2017 Posted November 26, 2017 strait fit as the g6 is 4efe to just make sure the selector brackets are on the box and that you mod the shifter Quote
maerijn Posted November 27, 2017 Posted November 27, 2017 Mine came from a different corolla with 4AFE so I had to swap the bellhousing to fit an E series engine Didnt have the selector bracket with it! However the seller had first delivered a 5 speed box incorrectly and I was able to use the bracket from that I didnt modify anthing to the shifter, what did you have to do to it Colin? Quote
Mxdsnny Posted November 27, 2017 Author Posted November 27, 2017 10 hours ago, Ollieh17 said: Better ratio for what? For ratoing, You know...... brraaaaap brrraaaap...... Acceleration? Motorway cruising? Quote
