damdrifting Posted December 27, 2017 Share Posted December 27, 2017 Hi everyone, I almost done my 4e-fte engine swap in my EE90. I wait new sparks plugs to start it. To waiting , i finished the wiring. I saw what my pin-out 9 " speed sensor is cut . So i think , the ECU will be in default ( code 42 ). But i would like to know if this fault code brings a" limp home" mode ? I had think to take a speed signal to my speedometer but mine is entirely mechanical, no electric wire ... So i thought to a another solution , install a SLD , but it costs expensive I would like to see with you if anyone has a good adress to order one it , or to sell it . Thank you ;) Quote Link to post Share on other sites
daniel_g Posted December 27, 2017 Share Posted December 27, 2017 I can sell you a hks sld. Not wanting that much money for it. Quote Link to post Share on other sites
5e colin Posted December 27, 2017 Share Posted December 27, 2017 Put some wings on your car our cart get very light above 200kph actually gets scarry Quote Link to post Share on other sites
damdrifting Posted December 27, 2017 Author Share Posted December 27, 2017 Thanks , the issue is not really to remove the speed limit but also avoid an ECU default :) Quote Link to post Share on other sites
