Does anyone know the thread size othe the oil pressure switch/sensor where it goes into the block ?
Wanting to get a remote oil pressure gauge adaptor but dont know if i need 1/8npt or 1/8bspt thread where it goes into the block
I know i need 1/8npt for the end i put my sensors for the gauges, just unsure about the end that goes into the block
Thanks
I think its just a mistake in the advert. If it says it fits most toyotas then it should be 1/8npt. If you're still unsure, message them first before buying.
Well ive seen one on the rspec website and its 1/8npt both ends amd i thought it was that until i saw the one i posted above which says its 1/8bspt but is to fit the starlet so im lost
