Just wondering would a ae111 lsd box fit in my ep70 with a normal efe bell housing on a 5e, the 5e is na and I was also wonderin which clutch and is there any light flywheels I could use? Also any other cheap ways of getting more power out of the 5efhe
no it won't fit without modifying bell housing and making up mounts as far as I know, if looking a 6 speed, a g6 corolla box will straight fit in, get a 3e flywheel off idworkz or tuning developments and you can fit a glands clutch other wise you'll have to look into high spec 4e clutches
As above, swap bell housing as a minimum but youll want to check the levin box has the bolt holes for the 4efe front box mount, if not youll have to put some in, or Failing that you'll need to swap all the ae111 internals into your box and if using a 6 speed box youll need the end casing from the ae111 box too as that houses some extra bearings
Or as above use a g6r box and that will all bolt up but you'll need to find an lsd for it.
