JDR33 Posted April 16, 2018 Posted April 16, 2018 Hi all, I need help trying to fish out a snapped end of a key in the ignition barrel. The end of the key snapped about 10mm and is prized inside. I've taken the steering wheel off and all the plastic surround thinking I could detach the barrel but it seems to join around the steering column as one whole piece with no access in to the barrel :/ Do I need to buy a special tool set or have I gotta take the whole column off and see if a lock Smith can release the key? Cheers. Quote
Nafeez2125 Posted April 23, 2018 Posted April 23, 2018 try to fish it with a thick paper clip and some strong super glue. apply a drop of glue on the tip if the clip and touch and hold it. and one its dry pull it out gently. Quote
