Need some more info dude, what actually happens when you get to 1/4 throttle?
Have you fitted any mods prior to this happening?
Just bogs out.. I found the king lead is all burnt out in the ends , could this be the problem?
Yep, you’ll find that it’s breaking down under load.
Id replace the whole set (if the king leads worn out the rest can’t be too far behind?)
should sort your issue out 100%
