Nafeez2125 Posted June 28, 2018 Posted June 28, 2018 Dear respected fellows, I recently bought a set of 10mm wheel spacers and while fitting them i found out that the wheel studs are too short to accommodate the spacers. after some research i found out that the studs specs should be M12 x 1.5 and spline diameter is 14.3 mm (correct me if im wrong). my question is will this wheel stud specs fit both front and rear? and is it big job that requires fancy tools? Thanks in advance lads. Quote
Calum122 Posted June 28, 2018 Posted June 28, 2018 Fensport sell longer wheel studs. I thought they were replacements when I bought some years ago. Went to fit them and they were like 20mm too long. I'm too trashed to send anything back. Two years later I was working on my car and found I needed them. So lucky I kept them. They're expensive, but it is what it is. Quote
Nafeez2125 Posted June 29, 2018 Author Posted June 29, 2018 does the one on fensport fit both front and rear? Quote
Calum122 Posted July 1, 2018 Posted July 1, 2018 I bought them all round, but only changed the fronts. I would have thought the fitment is universal all around the car. Quote
