BenV Posted April 16, 2008 Posted April 16, 2008 on my exhaust there is a clamp that doesnt turn to the side because it fouls on the heat sheild.i wouldnt mind but ive got stuck on a car park and hit it on a bump in the road which very nearly rip it off! could i take it off and put 2 jubile clips there instead? opinions needed asap as the rattle is doing my head in! Quote
montanajr Posted April 16, 2008 Posted April 16, 2008 Is it a U-Bolt on there atm? You could use two jubilee clips, but try 2 u bolts instead . much beefier! Quote
paul w Posted April 16, 2008 Posted April 16, 2008 Take the heat shield off or grind it back so you can fit a U bolt. ;) Quote
scutch0 Posted April 16, 2008 Posted April 16, 2008 jubilee clips probably wont be strong enough to do the job mate. i agree with paul, grind or cut the heatsheild away. Quote
BenV Posted April 17, 2008 Author Posted April 17, 2008 jubilee clips probably wont be strong enough to do the job mate. i agree with paul, grind or cut the heatsheild away.dim problem! how come i didnt think of that? will ave a crack on the week end. cheers guys! Quote
