Duduglanza Posted September 26, 2018 Posted September 26, 2018 hi guys. I bought a set of Rc 550cc low impedance with a resistor box from another guy. The resistor pack has only 2 resistors. Which way should i connect them to the injectors? thanks Quote
Stu Posted October 1, 2018 Posted October 1, 2018 I'm assuming your using an aftermarket ecu to run them? But wiring wise its pretty easy, conventionally the ballast resistors need to be wired into the power side but they can go into the drive side if need be. So 12v supply > ballast resistors > injectors < injector drives from ecu. They look like 50w 4r7's, just split the injectors into pairs so power > ballast #1 > injector 1&2, and ballast #2 > injector 3&4. Quote
Duduglanza Posted October 1, 2018 Author Posted October 1, 2018 yeah im will run them with the emu. So i just find the power wire on the injector harness .. cut and put the resistors in between? Thanks Quote
Stu Posted October 1, 2018 Posted October 1, 2018 Yep, just split the power wiring like I mentioned and you will be fine. Quote
