Galliano Posted April 16, 2008 Posted April 16, 2008 well, yet again the technical noob (currently learning though - go me ;)) is asking a questionwhat do i need to do to remove the anti-roll bar to be able to rub it down and spray it (yep.. make it look something its not)and what are the dangers of doing so? car will be jacked up at this point will anything fall off that is fatal to hold wheels/springs/brakes.. etc on the car (if i were to un-bolt the roll bar)cheersSam Quote
nic1.3 Posted April 16, 2008 Posted April 16, 2008 to take it off just undo the endlinks and take off the rubber d bushings that are underneath then there shouldnt be much more holding it on.if u do it rite then nuthing fatal should come off..... Quote
Galliano Posted April 16, 2008 Author Posted April 16, 2008 so theres 2 end links i presume, where would the rubber bushings be? Quote
nic1.3 Posted April 17, 2008 Posted April 17, 2008 yes there are 2 end links these bolt onto the lower wish bone thingas for the bushings theyre bolted on to the underneath of the body once the car is jacked up u really cant miss them Quote
StarletRick Posted April 17, 2008 Posted April 17, 2008 you do realise you cant see it, at all. from any angle. would be a hella waste of time. Quote
