LeonL Posted November 3, 2018 Posted November 3, 2018 Not sure if this is correct section or if should have put this into engine section. Either way: ep82 washer fluid bottle that mounts to coolant bottle. Is there anywhere selling these brand new? Struggling to find one, mines cracked (well has a hole) and mot is due end of month. Failing that if anyone happens to have one chuck me a pm with a price. Are there alternatives I can use that still fit well and don’t require much rewriing and routing? cheers Quote
Calum122 Posted November 3, 2018 Posted November 3, 2018 As I said, EP91 bottle fits in the wheel arch of the EP82 chassis, with the whole already cut out in the arch, so no need to modify the chassis. Quote
LeonL Posted November 4, 2018 Author Posted November 4, 2018 On 11/3/2018 at 5:14 PM, Calum122 said: As I said, EP91 bottle fits in the wheel arch of the EP82 chassis, with the whole already cut out in the arch, so no need to modify the chassis. It’s the wiring and rerouting of pipes that I can see being a pain? Quote
SKINY Posted November 5, 2018 Posted November 5, 2018 I may have a spare still, will check after work Quote
LeonL Posted November 5, 2018 Author Posted November 5, 2018 Brilliant let me know either way sir Quote
LeonL Posted November 13, 2018 Author Posted November 13, 2018 On 11/4/2018 at 9:24 PM, Calum122 said: Nope. Was simple enough How did you mount this? Are the mounting points present or did you need to fabricate? Quote
Calum122 Posted November 13, 2018 Posted November 13, 2018 16 minutes ago, LeonL said: How did you mount this? Are the mounting points present or did you need to fabricate? One hole lined up, then I just drilled through the wall and rivnut'd the bottle in place. Quote
LeonL Posted March 27, 2019 Author Posted March 27, 2019 On 11/13/2018 at 1:44 PM, Calum122 said: One hole lined up, then I just drilled through the wall and rivnut'd the bottle in place. Ive now done this but bumper no longer fits with fog lights? Fits with fog light removed, how did you get around this? Quote
