Tray Posted January 23, 2019 Share Posted January 23, 2019 Anyone can help me with a guide for installing gauges in my car.specially he wiring parts how to find acc and so on. Thanks in advance Quote Link to post Share on other sites
SKINY Posted January 23, 2019 Share Posted January 23, 2019 How many wires have they ? 2 wire guage I use the sidelight circuit for + and then any handy earth, normally a good earth point in behind the radio. 3 wire have ignition and a switched(sidelight feed) + . Easiest way to find the + circuit/circuits is pull the ignition surround off and use a fuse/circuit tester to find the wire/wires you need to tap into Quote Link to post Share on other sites
Tray Posted January 24, 2019 Author Share Posted January 24, 2019 Its a defi link types got it from a friend its fir wires i think have to check il give it a shot weekend Quote Link to post Share on other sites
BMX-RIG Posted January 25, 2019 Share Posted January 25, 2019 If you have the loom adapter to put a headunit in, the wires are normally labelled so it makes it easy to know whats what. Quote Link to post Share on other sites
