paddy Posted March 12, 2019 Posted March 12, 2019 My Glanza died this morning, was going along just fine, went to put my indicatiors on, every time they flashed it cut the engine out, also got a massive smell of fuel from inside the car, anyone have any idea what’s causing it? Quote
H_D Posted March 12, 2019 Posted March 12, 2019 check the bulbs aint bridging, regarding the fuel smell check for leaks Quote
paddy Posted March 12, 2019 Author Posted March 12, 2019 Just had a look, both front bulbs are blown, I’ll get them changed ASAP, is there a relay for the indicators? When the car cut out this morning form the indicators it flooded the engine, was running on 1 maybe 2 cylinders which a huge cloud of white smoke out the back which was un burned fuel Quote
paddy Posted March 12, 2019 Author Posted March 12, 2019 Update - both front bulbs are fine, they’ve not blown, they just do not light up. When the car tries to light them up it cuts the car out. Rear indicators work fine. I tried different bulbs in the front - same problem. Has anyone got any other suggestions? A bit stuck with this one, mot is due next week. I’ve check all earths under the bonnet, nothing is loose Quote
