Been having problems with getting boost at low rpm, was wondering if there are any common issues with these that I could start to look at. No engine management light on cars pretty much standard. Thanks
What turbo do you have on? Any vacuum leaks noticeable on the boost gauge?
On the gauge, at idle you should be reading -20 or a bit more.
HI there,
If you list the full spec it would be helpful.
You say fairly standard so i would guess its on a CT9 still? Does it have an adjustable actuator? If this is set incorrectly it can cause low down lag.
Check the other basics, boost leaks, exhaust leaks etc etc.
