StarletDS Posted July 12, 2019 Posted July 12, 2019 (edited) So I’ve had a quiet whine coming from the gearbox area for a while now, all of a sudden last night on boost it felt like something completely broke apart. It still goes into gear but it crunches and squeals really loud to the point it jerks the whole car if I’m trying to accelerate. If I sit at idle you can hear something grinding and then when I press the clutch you can hear it slow down and eventually stop. It stills goes into gear fine although reverse is quite a struggle now UPDATE: today I went to move it a couple of meters, lots of crunching and it felt like something locked up, now I can’t engage any gear with the car on or off. And I can’t push the car backwards even with the clutch pressed and the car off. It’s as if I’ve parked it in gear even when in neutral. Any help would be GREATLY appreciated, it’s an OEM LSD box Edited July 12, 2019 by StarletDS Quote
Stu Posted August 5, 2019 Posted August 5, 2019 Could be a chunk of something has got into the diff ring gear. Ive had that before. Locked it up good. Quote
