Lewis Aston Phipard-shears Posted July 31, 2019 Posted July 31, 2019 Hi looking for some advice on my ep91 when I put my foot down and give it some I don’t seem to be able to change/find any gears. 1st to 2nd won’t go in and 2nd to 3rd is the same. is this the gearbox giving up or something to do with clutch as it only dose it when flooring it ? Car has updated clutch not sure what tho and not to long ago had new master cylinder and slave cheers Quote
Patches Posted August 1, 2019 Posted August 1, 2019 15 hours ago, Lewis Aston Phipard-shears said: Hi looking for some advice on my ep91 when I put my foot down and give it some I don’t seem to be able to change/find any gears. 1st to 2nd won’t go in and 2nd to 3rd is the same. is this the gearbox giving up or something to do with clutch as it only dose it when flooring it ? Car has updated clutch not sure what tho and not to long ago had new master cylinder and slave cheers I've got the same thing happening with mine so keen to see what answers come up. Quote
akyakapotter Posted August 1, 2019 Posted August 1, 2019 Check you still have the clips for the cables gearbox end I lost one on track and gave the the issues you have. Cheers nick Quote
Patches Posted August 1, 2019 Posted August 1, 2019 2 hours ago, akyakapotter said: Check you still have the clips for the cables gearbox end I lost one on track and gave the the issues you have. Cheers nick I'll check this when I get to the car after work, cheers man! Quote
Lewis Aston Phipard-shears Posted August 1, 2019 Author Posted August 1, 2019 20 hours ago, Lewis Aston Phipard-shears said: Hi looking for some advice on my ep91 when I put my foot down and give it some I don’t seem to be able to change/find any gears. 1st to 2nd won’t go in and 2nd to 3rd is the same. is this the gearbox giving up or something to do with clutch as it only dose it when flooring it ? Car has updated clutch not sure what tho and not to long ago had new master cylinder and slave cheers Had a look at mine just now and can’t see anything missing or loses any other ideas? Quote
akyakapotter Posted August 1, 2019 Posted August 1, 2019 Maybe the slave cylinder playing up try change the clutch fluid / bleed it. Quote
Lewis Aston Phipard-shears Posted August 1, 2019 Author Posted August 1, 2019 Cheers mate Had abit off a play round with it bleeding it didn’t help but think I may have sorted it by adjusting the biting point on the pedal Quote
