Front mats, standard brakes (new), optional rear speaker kit
After a few little bits.
front standard mats as want to keep it as original as possible.
standard brakes, pads and disc.
glanza rear speaker option?? Sure I saw something like that.
cheers joe 👍🏼👍🏼
Find an n/a parcel shelf with speakers and loom, then dissect them off and fit them to your glanza shelf. The holes are marked on the underside of the shelf for easy fitting.
If the n/a is being broken up you will be able to get the loom that runs from the shelf to the headunit for an oem install.
