Lmooreep91headache Posted November 28, 2019 Posted November 28, 2019 New member I really need some advice if anyone could help thatβd be great. Recently got a gls 4efe full glanza rep in the hope of going turbo. The previous owner was kind enough to give me the old fte ecu all the looms key barrel etc. Iβve swapped everything over and bolted it all together, theoretically itβs ready to drive.Β Iβve changed igniter dizzy the leads etc. I have Strong spark and Iβm definitely getting fuel as the fte injectors leaked until I changed seals. However it point blank will not fire. Iβve spent all day playing with dizzy timing and it wonβt start at all Iβm really confused. Any advice would be hugely appreciated as Iβm completely out of options I just want to take it for a play now. Thanks in advanceΒ Quote
maerijn Posted November 29, 2019 Posted November 29, 2019 did you do anything to the engine timing? Quote
Lmooreep91headache Posted November 30, 2019 Author Posted November 30, 2019 Okay it turns out Iβve been silly. As previously mentioned I know the pump works I changed injector seals and heard the rail build pressure again so I stopped hunting for fueling. Turns out my injectors arenβt firing as the new plugs are bone dry. Everything else appears to be in order I just need to figure out why i have no injector pulse and hopefully weβre all good π€π» Quote
