dcbr Posted January 5, 2020 Posted January 5, 2020 Hi guys. I have a forged glanza V, I have recently bought all the bits to finally run some power since the cars been forged in 2014. The current setup is a externally gated TD04. the map on the emanage ultimate is for a TD04 @1.2 bar I’ve been told. When I’m getting it fitted I’m also going to get my 440cc injectors, fuel pressure regulator and my Walbro 255lph fuel pump on. would I have any problems? Also what do I set my fuel pressure to.. anything else I need to do? Quote
akyakapotter Posted January 5, 2020 Posted January 5, 2020 You'll need a remap to suit your set up and engine bud leaving it with the map that's on it is bad news. Cheers nick Quote
dcbr Posted January 5, 2020 Author Posted January 5, 2020 52 minutes ago, akyakapotter said: You'll need a remap to suit your set up and engine bud leaving it with the map that's on it is bad news. Cheers nick Do you know what I would need to set my fuel pressure to? Quote
akyakapotter Posted January 5, 2020 Posted January 5, 2020 Again would leave that to the mapper not worth messing with it yourself bud Quote
