Timo204 Posted January 22, 2020 Share Posted January 22, 2020 (edited) Hello everyone, As the title suggests, my tranmission started making some noise a while ago. It doesn't seem to get worse, but it sure doesn't sound like it should. It's a 1997 Glanza V, stock transmission with the factory LSD. The car has done 137000km's. It starts off with a howling sound, but goes into a shot-bearing sound. There's no difference in noise when pressing / depressing the clutch pedal at a standstill. If I push the clutch pedal in while driving, the noise goes away. The noise is also audible when putting the transmission into first gear while the car is still rolling. If anyone has had similar/the same problem, and actually fixed it, I'd love to know. I've posted a video below, showing the noise. https://youtu.be/2y9nPwNiuYQ Edited January 22, 2020 by Timo204 Quote Link to post Share on other sites
lukEp Posted January 22, 2020 Share Posted January 22, 2020 (edited) Starlets are known to have a "noisy gearbox" and mine sounds just like yours. It might just be something you've only noticed since getting used to the car. Have your wheel bearings checked as this can make a similar noise. Edited January 22, 2020 by lukEp Quote Link to post Share on other sites
akyakapotter Posted January 23, 2020 Share Posted January 23, 2020 Be swaying towards bearings in the box gone bad my other box is like that hence why I took it out. Cheers nick Quote Link to post Share on other sites
