Hi I want to see if there are any fault codes stored on my Toyota starlet glanza v. What sort of code reader can anyone recommend. Only can see code readers OBD2 then you can get an adapter for the ep91 glanza v too fit for the OBD2 is this the right thing to do or am I likely to fry my ECU?
The adapter is on Ebay item number 263971947504
1 minute ago, Sam44 said:
It's blink codes. You link out 2 pins in the diagnostic socket and read the engine warning lamp flashes
Is this the only way o do this then and where do I link the pins which pins
Thanks
