Duane Duane Posted February 29, 2020 Share Posted February 29, 2020 Hello guys I have a 98 glanza but im having problems with the crank signal I already put in new plugs a new rotor and rotor cap measured the dizzy wiring for continuity but its still not firing so im all out of idea’s does any one know some other things I can try? Quote Link to post Share on other sites
T-dog Posted February 29, 2020 Share Posted February 29, 2020 Has it just happened ? Or have you done anything to it lately ? . Check that the igniter is grounded good against the bulk head 👍🏼 Quote Link to post Share on other sites
Duane Duane Posted February 29, 2020 Author Share Posted February 29, 2020 On 2/29/2020 at 1:44 PM, T-dog said: Has it just happened ? Or have you done anything to it lately ? . Check that the igniter is grounded good against the bulk head 👍🏼 Expand Bought the car as a running but needs work car (it had a td04 external gate rx8 injectors ect..) so put on a stock mani stock turbo stock cat (didn’t notice the rx8 injectors by now) hooked up the radiator and put in coolant and guess what coolant came out the exhaust. Replaced the head gasket and it ran okay ish high idle and it smelled like gas a lot also the temp gauge wasn’t working so i replaced the temp sensor and boom high idle gone and ran a lot better still smelling a lot like gas and it ran really bad under boost so I went looking and did a diagnose. (Map sensor bad and crank signal code 10) changed the map sensor it was still running then thats when I noticed the rx8 injectors so I changed those for some stock ones and it was still running then from one day to the other it just doesn’t start any more and is still trowing code 10 no crank signal. Thats the story until now Quote Link to post Share on other sites
T-dog Posted March 2, 2020 Share Posted March 2, 2020 (edited) Very strange one . Could well be a issue with the dizzy unit itself then . As if it was just running fine now it won’t and you have no spark and all wiring is good . Have you 100% checked all the grounds and the wiring plugs are good ? Edited March 2, 2020 by T-dog Quote Link to post Share on other sites
Duane Duane Posted March 2, 2020 Author Share Posted March 2, 2020 On 3/2/2020 at 5:28 AM, T-dog said: Very strange one . Could well be a issue with the dizzy unit itself then . As if it was just running fine now it won’t and you have no spark and all wiring is good . Have you 100% checked all the grounds and the wiring plugs are good ? Expand About where are all the grounds ? It does spark but the spark is a bit yellow ish Quote Link to post Share on other sites
maerijn Posted March 2, 2020 Share Posted March 2, 2020 (edited) thick ground wire from gearbox mount to battery negative terminal another ground is on the back of the inlet manifold additionally you could add a ground from the right engine mount to the chassis Edited March 2, 2020 by maerijn Quote Link to post Share on other sites
Duane Duane Posted March 20, 2020 Author Share Posted March 20, 2020 On 3/2/2020 at 2:20 PM, maerijn said: thick ground wire from gearbox mount to battery negative terminal another ground is on the back of the inlet manifold additionally you could add a ground from the right engine mount to the chassis Expand Im gonna check them all and put in another ground thanks for the help il let you guys know if it works Quote Link to post Share on other sites
