Sign in to follow this
stucat87
Engine tap
Right. Cars been at mechanics. Had a knocking crank, so that’s been replaced. And engine has been running perfect, but I’ve still got a knocking from my engine. Car runs and drives flawless.
if I hold the steering hard left or right noise goes away. But when I let go it comes back. Anyone any ideas what could be causing it.
Share this post
I think the only reason the noise is going away when you turn the steering is because the engine rpm is changing.
The engine sounds like the bearings are worn. This noise will be louder when engine is warm whilst at idle.
Oil pressure lower so you can hear it more.
what did the mechanic replace? Because it sounds like you have same problem.
Share this post
