Nafeez2125 Posted September 16, 2020 Posted September 16, 2020 Hi Guys, Hope everyone is ok. can someone please help me find a wheel hub for a starlet Glanza V. cant find it anywhere for sale but i came across a hub for yaris and not sure if its going to fit, does anyone know the specs for Glanza? Yaris hub specs: Width [mm] : 68.5 Outer diameter [mm] : 125 Outer diameter [mm] : 38 Bolt Hole Circle Ø [mm] : 100 Outer thread [mm] : M12 x 1,5 mm Fitting Position : Front Axle Many thanks Nafeez Quote
td04 turbo Posted September 16, 2020 Posted September 16, 2020 3 hours ago, Nafeez2125 said: Hi Guys, Hope everyone is ok. can someone please help me find a wheel hub for a starlet Glanza V. cant find it anywhere for sale but i came across a hub for yaris and not sure if its going to fit, does anyone know the specs for Glanza? Yaris hub specs: Width [mm] : 68.5 Outer diameter [mm] : 125 Outer diameter [mm] : 38 Bolt Hole Circle Ø [mm] : 100 Outer thread [mm] : M12 x 1,5 mm Fitting Position : Front Axle Many thanks Nafeez There's 4 on ebay Quote
